@Biggles50 I use mainly MiG’s enamel washes, my two favourites being “Dark Brown Wash for Green Vehicles” and “Brown Wash for German Dark Yellow”. I’m not sure that you’re actually allowed to use them on aircraft but I trust you to keep the secret… They can be further tinted using oils or Humbrol enamels and are easily cleaned up and controlled using “Odorless Thinner”, even if they are dry to the touch they can be re-solved and manipulated for several hours afterwards. I let them set for 24 hours or so before sealing them with a quick and thin layer of MrP “Super Clear”. I suppose any enamel washes will do fine, it’s just that the MiG ones are the easiest to get for me!
@Russelle I think it starts with either Lego or plastic models (or both for the more advanced cases
) as a kid, and then engineering is the natural progression to that - the chance to continue doing more or less the same thing while getting paid for it
! When I was active in IPMS Stockholm there were lots of people working in different areas of engineering, quite a lot of people from the military and, rather surprisingly, more than the average share of conscientious objectors proving that you can actually like German armour without necessarily wanting to kill someone
Cycling? Of course. An advanced case - both MTB and road
. And it has for many years been my main mode of transportation to work. I’ve never been a car-guy though, I make do with a very ordinary Volvo V90
And now on to the actual modelling
I wasn’t too happy about my choice of a black base for the metal finish but after leaving it for a week I somehow got used to the look, next time I’ll try a grey base though!
I used a few different colours from the MrP metallic paint range…
…but most of the “aluminium”-versions are very similar…
…in order to get a bit more contrast, mixing with “burnt iron” gave a much warmer tone to some panels.
It’s not that obvious in the photos but I mixed in some Gunze H53 grey for the rudder and elevators that were fabric covered on these Mustangs to get a bit of a contrast. Later ones got all metal flying surfaces.
Painted on markings followed the usual process that you have seen a bunch of times before, I spare you this time! Now the trouble starts, putting decals on the NMF… I wish Arma had used the same decals as Eduard where you actually can peel off the film afterwards - oh well, I’ll figure something out
Magnus
