That’s really cool! Didn’t realize the front wheels went up in an arc until now.
—mike
—mike
I don’t know but it looks like he looked through the cab windows and positioned the TM from experience. Similar to how you can drive your car directly over an aluminum can in a parking lot. I’m speculating
Have you found any more pictures or video of the project you’re work on?
Yes, this was also built accordingly
https://www.youtube.com/watch?v=Oz9lRuwQvAw
audio: RIP Lee Scratch builder Perry
Looking great, KSO! I left these details of the gauges more or less out on my FUG.
Maybe I should’ve as well. I still need to glue in the ‘glass’ from the inside, after cab assembly
Holy Moly… that looks difficult to remove later
I watched your build thread and you removed those masks after paint AND assembly
Oh, did I confuse you? Sorry! Of course I only masked the outside of the clear parts but after I glued them to the cabin parts. The masks only shine through to the inner side.
Sorry again!
Lol, ok no worries. I see that now. I’m still going to build first so I can putty and fill gaps (if needed) because the FUG and the Trackmobile cabs look like solid structures with no seams between each side panel.
However, your model looked solid. I dry fitted my cab parts and saw potential seams… just making sure
Primed and base color on. Enamel safety green so this will sit for at least a week before masking the rubber window trims
Dry fitting I discovered that the road wheel arms need to be extended further so the drive cones on the traction wheels will make contact like the real thing.
Nice movement!
—mike
