Gerrit, my head is spinning just looking at the blades ![]()
Looking forward to see more ![]()
I got a little fear before the paint job on the props . So many corners !!
Been working on this one for a bit. I am aiming for something like this.
The floats was built a while back. Tonight I built everything else. Added sheet styrene for the back of the seats.
This seems to become a beautiful model, seeing the original aircraft ![]()
Good luck! ![]()
Basic colors are on. Some of the resin parts are losing paint, but should be easy to fix. Still some touch ups to do, but looking good so far. ![]()
More to follow ![]()
Since this is all supposed to be aluminum, I thought I would built it as one to make it easier to putty before paint. Either I will be an idiot or a genius time will tell.
I have finished the touch-ups and added a coat of gloss varnish. From the beginning I wanted to use squiggle camo on top. Now I am afraid to ruin everything ![]()
What do you think? Go straight to decals or do the squiggly camo on top?
Well, this is a stretch and I may never finish, but I think I’ll give this campaign a go.
Hasegawa 1/72 Aichi E13A1 Type Zero (Jake) Model 11 ‘Kimikawamaru’ w/catapult
フライネイビー!
—mike
Always the big question, I noticed there’s even a topic named after it… to paint or not to paint… ![]()
Hi Jesper, Are you thinking squiggles on top of the splinter pattern you’ve already painted? …![]()
—mike
But this Jake has a loftier view! ![]()
Working bass-akwards — so what else is new? I began building the catapult when I had one of my bright ideas. … Rummaging speed! … And why I collect bottle caps. ![]()
Couldn’t ask for a better fit! ![]()
Now to add that box thing and a couple of ladders. ![]()
フライネイビー!
—mike
Some inspiration Mike. Kit instructions of kits of, or with, Japanese catapults:
@ Peter (petbat). Thank’s. That first pdf is actually the same Hasegawa kit that I’m currently building. The second pdf looks to be a slightly different variant. Assembly is almost done here. The blue bottle cap has been added to extend the height of the base to resemble the reference image.
Here’s a quick catapult dry-fit shot. This went together very nicely. No warping, nice detail, good connection points, very little flash, a few sink marks that I might or might not need to fill (inside).
I believe I have some leftover ladders somewhere, but I’ll need to source some diamond plate for the round deck. ![]()
I hope the Jake goes together as nicely as this did.
フライネイビー!
—mike
Mike, what scale is this?
Hi Matthew. It’s 1/72 scale.
—mike
Hi Mike @justsendit - exactly! Now I am just worried I will ruin everything. It is difficult to paint squiggles ![]()
What do you think? Should I go for it?
I quite like it the way it is Jesper. I don’t recall any German seaplanes with squiggly lines or anything else. This banded camo type is how German seaplanes looked, and although this is a ‘What if’, I would keep the camo period perfect if I was the one doing it.
It is your model though, so go for whatever you want. ‘Nothing ventured, nothing gained’.
I like it as-is. I’m no expert, but I somehow don’t see squiggle camo working over water.
Personally, I’d save the squiggles for another more appropriate aircraft. … Like the Heinkel He219 Uhu!
—mike
Perhaps just outline the camo with the lighter colored lines and leave it at that. That would still look very impressive!
