Hello everyboy,
unfortunately, in the photos one cannot recognize the course of the GH2 Press. Line so good like that of the GO2 Press. Line, which is why I could not measure the length of the slant up to the lower two bendings directly. ![]()
Therefore, after putting the Attachment on the ET, I could only mark the distance to the first bending after a painstaking threading of the dummy across the LO2 Feedline and through the opening of the small Support in front of the TPS Cladding, what a stressful fiddling was. ![]()
Then I’ve tried to get made the two bendings with the round tongs in the smallest spaces, especially since their distances are minimal, as can be seen from this image.
Source: georgesrockets.com (George Gassaway)
And that’s how the bended Copper dummy looked like,
which one can see here in the provisionally installed state. ![]()
But somehow the shape and size of the lower bows did not agree, which were a bit too big, ![]()
because, as one can see on this image, the upper bending in front of the slant is much closer to the GO2 Press. Liner. ![]()
After this first impression, I’ve immediately took the Steel wire (Ø 0,4 mm) and bent it, but it is much harder and more resistant and therefore more difficult to bend, especially in the lower part of the double bendings, which is why several trials and test fittings were necessary. ![]()
At that it turned out that one can perform the lower two bendings only halfway accurate, if one leaves at the lower end first a longer end piece in order to be able to bend at all, and this only then shortens accordingly afterwards. ![]()
Threading the line was only possible directly at the Attachment,
whereupon it could be put then onto the ET, in order to try then to insert the lower end into the rear Ice Frost Ramp (R24), but what was not successful instantly, because sometimes either the inclination of the slant or its length was not right, or the distances of the lower two bendings, or all together, what was enough to drive you up the wall … ![]()
Therefore I’ll show you the (preliminary) final result after the umpteenth attempt, ![]()
which was then satisfactory. ![]()
This was followed by (only) still the exercise with the threading of the two Fittings, whereby the action at the lower end still before the threading of the Press. Line under the Crossbeam was comparatively harmless. ![]()
But then came the critical place in the circled gap, for what the line in front of the support had to be fixed with a mini-tape strip (arrow) in order not to constantly slip out again. ![]()
And then I’ve channeled the Fitting ring, which was hanging at the Toothpick-Tape-holder again, into the gap, and carefully inserted the line with the sharpest tweezers, what then sometime has worked again … ![]()
But even to photograph these details, some pull-ups and appropriate mountings were needed to get close enough into a suitable position with the digicam,
in which the autofocus (with self-timer) could still focus, as one can see here. ![]()
All in all, a rather time-consuming business with the scratching of such tiny details,
whereby the joy is even all the greater when it has succeeded in the end. ![]()
To do this, I cut a 9 mm wide strip and wrapped it around the strut a few times until it had a
