T72..... A bit damp
Cut away this much of the rear bank to give the wagon a better position…
Added the missing fuel tank pipes.
Hacked off the end off the barrel and will be going for this type of positioning…
Order of jobs. Paint wagon today.
Begin the rear bank groundwork and make sure wagon sits in it ok.
Paint up groundwork.
Fix wagon into base. Build up lower levels by about 1.5cm and paint up a dirty earth brown…
Make sure all corners and edges are sealed.
Start acrylic pour… Then decide on the level to finish at, and cut back the balsa sides and front
Before final pour, detail paint tank with rust, grime, slime and moss effects and build up of silt.
Add the river bank foliage and start final pour …
Looking good. :memo: :white_check_mark:
—mike
Base coat fine on the T72… XF 65 …will do another coat tomorrow and then a coat of lightened NATO green…
Once I’m happy with that, I will pick out individual ERA blocks in a few different shades of green.
Rock plaster bandage applied for the start of the groundwork…
Also, you may notice I removed about 1cm from the rear wall so it’s level across the whole length now.
Once the rock plaster is fully set… I will smooth over plaster of Paris to even it all out …
Good looking process. :+1::+1:
You could fill the hull with a filler so that any leaks to the interior would be small and not cause any issues with the pour volume. Modeling clay? Sand, Plaster etc… The weight would also reduce the tendency to float.
Zvezda… :face_holding_back_tears:
Already sorted Greg …the hull has been totally sealed and will be anchored to the base by filler before the pour begins :+1::+1:
It is a very unrecommended kit … Sean @Seanmcandrews said earlier in a missing post that it’s a rebox of an old equally bad Dragon kit …
Your project is coming along very well John. The tank looks fantastic. Congrats on getting it together. This is going to be an excellent scene.
Looking forward to seeing how this pans out John, especially the scenics, :+1: :slightly_smiling_face:.
How do you intend to get the silty appearance?
G, :beer:
Honestly… Not sure lol…
For the rear bank where it’s given way, I have also ordered some AK Terrains Wet Ground which I’m going to try on that …
The silt :thinking:, firstly it will only be on the higher hull area… I was thinking initially to mix some earth pigments with the MIG acrylic resin and carefully apply that in recessed areas, corners, in between the visible ERA blocks, that mixture will have a permanent semi damp look once dry, I was then going apply some earth/sand mixture pigment on top of that but sparingly and then fix that in place to try and give those areas a silty wet bottom going into dry look on top if that makes sense …
Thank yee kindly Sir :grin:
2nd coat of XF65 on…
Will mist that over with a thin overspray of NATO green…
Collapsed bank 3/4 of the floor now have a layer of plaster of paris over it…
Will get a base coat of paint on it tomorrow…
That stuff gives you great effects! Especially in combination with the puddles stuff…
Just discovered this topic… Nice process you make there Johnny! One thing that would be a great addition would be an oil trail going with the stream, from a leaking fuel line or something like that… I just haven’t the faintest clue how to create it!
Thats perfect Bert, and I am very glad I have ordered it… it is exactly the look on the rear bank I was looking for … thanks for showing that image.
Glad you found it Erwin … I had been thinking the same thing. My plan was once I have done the main acrylic pours and do a level of the AK puddles pour, I will let that fully set. Then I was going to use some x19 tamiya smoke and try and make some flow patterns and build up of spilt fuel around the external fuel drums. Once that has fully dried, i would pour a very thin level of the AK puddles on top of it… or something along those lines ???
The big challange would be the rainbow like colors of the oil/fuel.
I had thought about testing a small area on scrap plastic with the AK puddles, then blending x19, x23 x26 & x27 …? or just carefully brushing them close to each other so they blend together naturally ??
It is always worth trying… :slight_smile:
