I re started my airbrush spray booth project, I say re started because originally I was using foam core boards, but gave up on that material due to fitment and strength (or more precisely the lack there of) of the material. This round I used corrugated plastic sheets. They’re actually lighter but far stronger than the foam core. Another benefit is they’re waterproof.
In the end this spray booth will have two 140mm high static pressure computer fans, giving me around 200-240 cfm total air movement. I have led light bars and filter material (sourced from Home Chef freezer box insulation (spun fiberglass 1.5 inch thick) and a second layer of carbon filter. To keep everything clean I plan to line the spray area with freezer paper that I can change out as necessary.
The booth is 19" wide x 13" tall with about 15" spray area depth. That is a 32 inch monitor behind the booth for reference.
After a long absence from modelling due to a summer job, made the genius executive decision to start doing the tracks on a T-55AM that I started before the break. The tracks have 3 sprue attachment points, 2 pin marks, and require the insides of the track being filed to fit the links before it. All in all, not the best thing to do as my return to the hobby.
