Now the hard part, with the DEF late M551 barrel in hand, I’m trying to decide, do I start on my Cold War Sheridan or the M60A2…or finish one of the 30 other half complete projects?
It does take some practice to get the paint/thinner mix right and what pressure to use. I suggest googling airbrushing with your preferred paint brand and check out the videos that pop up. That will give you a good head start.
As to actually laying down paint on your model, practice on an old kit first, if you have any. Test how your set up works for you, then when you are comfortable, get to work on the real kit. This is what I did and was thankful it was only an old junker that I stuffed up first time around!
Thanks, I don’t have the ability to use a booth right now so I’m sticking with water based acrylics. Based on my reading they seem to be harder to get the setup right for so that should be fun. I don’t have any old kits as I’m starting fresh after a 25 year break but i bought a basic kit to start with partly to get the hands and eyes coordinated again but also because I knew I would need something to practice painting on.
If you’re airbrushing acrylics without a booth I’d recommend you try using Mission Models paints - they’re more expensive but they aren’t nearly as toxic as any other brand of hobby paint
If you are just starting back, I would suggest using Tamiya paints first. Far more forgiving than other brands. Use their Lacquer Thinner, not their Acrylic thinner and you will have less issues - but spray outside if you don’t have a booth. The acrylic thinner can dry very quickly and leave a grainy coat on the model, which is why many modellers use the lacquer type. Try a 50/50 paint to thinner mix on a pressure between 12 PSI to 20 PSI at first. I actually add gloss to my Matt paint mix and that seems to give a smoother even coat.
Not sure of your genre, but if you do armour then you can test out on the inside of the hull and upper superstructure if that will not be seen later. Just keep paint away from where you will join parts on… or another option to test out, is buy a few sheets of Evergreen styrene card and spray that. A cheaper alternative than a wasted kit.
Good luck and enjoy the return to the hobby. Look forward to seeing you posting on here in future.
I started buying tamiya acrylics as thats what i used before but apparently in the time I’ve been gone safety has become a much bigger thing (rightly so). My space is in my basement furnace room with no windows or vents to outside and a gas furnace so no option for a booth and being in Canada spraying outside would be limited to about 4 or 5 months a year. I bought some ammo paint and will give that a go to start. One of my local stores did sell Mission paints but they are clearing them out so I didn’t think it was wise to buy into something that wont be stocked going forward. All my reading points to the tamiya, gunze or AK real color with lacquer thinner being the way to go so I will try and find a solution that gets me there safely but baby steps for now.
I’ll have to change some parts and add a second Bosch light to make it look like the vehicle I’ll model though.
Intend to open a topic, where I’ll build this and 3 other kits(2 of them still expected to arrive) as Bulgarian Maybachs from 1943-1945 and I hope the information I will provide lures other modellers to join with builds,
I have a bit of a Nam head at the momemnt.
The boat is for an ongoing Tet '68 Eve of Destruction dio. the figure kits for a few other ideas I have in mind.
