1942: The Turning of the Tide
Finished up the Wildcat today.
I’m still waiting for the case to arrive, once I’ve got that and have made the diorama, painted figures etc I can get some better shots. I’d lost the light (big storm just came over as I got set up for photos) and the flash caused a shadow and gave the dust a gritty look.
Still, a really nice little kit that goes together well. It’s probably not as good as it’s competition from Arma, but a good cheap alternative.
Very nice build, Stephen! Looks great and I am looking forward to see the diorama.
Congrats on finishing! :slightly_smiling_face:
My Hs-129 is beginning to take shape.
The cockpit is basic and although it will be hidden behind 2mm clear plastic I still added some PE seatbelts.
The engines were a real problem. The engines are not a tight fit in the cowlings, so a nightmare to get to sit at the right depth and aligned to avoid a crocked pointing propeller.
More to follow soon. :slightly_smiling_face:
Thanks, the idea I’ve got is that it’s just landed and the pilots talking with his wingman. Hence the dusty look. I’m going to look for the old Airfix USAAF ground crew set to find another member of the cast or two.
Looks good. Have been meaning to add a Henschell to the collection for years.
Nice build and equally nice finish on the Wildcat… Great job.
Thanks John.
It’s a really nice little kit and recommend for a little no nonsense quick build.
More great work here!
On another note, I haven’t really worked with awards since the new site came on line, but I gather that they’re becoming common now. If anyone here wants to take a crack at one for this campaign, let us know and we’ll see if we can cobble one together.
Michael :israel: :stuck_out_tongue:
Starting to see the finish line. Need to add the flag decal on the stern. Don’t know how old this kit is or if the decals are still alright. I’ll mount it on a water base. For the base I still need to add waves at the bow & then paint whitecaps, then coat in Modge Podge and install the Fubuki destroyer.
My HS-129 is ready for some sand squiggle camouflage. It will be quite a challenge, but I hope I can pull it off.
More to follow soon :slightly_smiling_face:
This took two layers of lines - first one and then 30 mins later another layer redrawn on top of the previous pattern. Gives a nice feathered look. I am very satisfied with the result, but needs to rest my eyes now :grin::grin:
That HS-129 looks great. Awesome airbrush job with the squiggles.
That’s awesome. You used the marker for that?
Great work on those disruptive lines Jesper. They look really good
Beautiful, I would go crazy trying to do that pattern…
Thanks for the comments, guys :+1:t2::slightly_smiling_face: Much appreciated.
It took some hours, but it was worth it in the end.
@phil2015 Phil, I used one of the relatively new AK Interactive real colors markers. I used the RAL 7028 color. Works well for something like this, but I would never paint an aircraft or AFV with it for the main camouflage, but it has its uses.
I suppose i should really get on with this. AH-1G is in hold whilst waiting for oarts so im getting on with this…
With a vehicle from the 2nd Dragoon Guards at El Alamein
Although pretty simple it builds into a nice kit.
The tracks are the usual rubber band style and a bit warped
So i decided to 3D print some. Magnifying glass at the ready
Those tracks are nice! That was always the downside of these early Italeri kits - the actual tank is pretty good.
Colin, the replacement tracks looks good. Looking forward to see more once they get assembled.
Here is my final entry for this campaign. The old venerable ESCI 1/48 HS-129.
It is build as some of the first machines sent to Africa in Oct/Nov 1942. They were very successful in the beginning, but quickly developed serious problems due to dust in the engines.
This was an excellent opportunity for me to try the desert squiggle camouflage with the new AK-Interactive paint pens. Very satisfied with the result and I am definitely going to try this again later on other models.
IMG_6444
IMG_6443
IMG_6442
IMG_6441
IMG_6440
