In a word no. I’ve seen a few vids on Future, but obviously missed this little gem!
Following the vids, I airbrushed 2 light coats of Future and set used Microsol ( the blue one ) under the decals.
They all settled well except the bigger ones. Gino’s explanation covered the “placing onto dried Future doesn’t always work” issue, as have you. But from another angle.
Only last night I was pondering throwing the near-full bottle out, now I can keep using it - but properly.
Quick question. Do you sealcote the whole model first, then wet the decal areas?
My answer to your last question might possibly surprise you as it flies in the face of everything this group has been taught . . .
I spray the model with Matte Clear (Tamiya TS-80) BEFORE applying the decals!
I spray it on very dry to give the decal a slightly rough “toothed” surface to adhere to. I then BRUSH ON some Future just in the area where the decal is to be applied and while the Future is still wet I apply the water soaked decal. As this starts to set I will apply another top coat of Future to completely entomb the decal.
(This also does wonders to build a tiny transition curve/ramp between the model surface and the edge of the decal film, usually making the edge disappear entirely.)
I allow this all to dry completely (overnight) and then go over the decal area with several more coats of Matte Clear to hide the shine of the Future.
I try to preach this technique far and wide on this site but usually I get responses like “no way”, “old fashioned” or “Solveset is better.”
So to those folks that scream NO, I just say “whatever is working for you keep doing it!”
BUT . . if you are having problems successfully applying your decals then you MIGHT just want to try it my way! *
*Not really even my way. This technique was taught to me by Monte Kelch of Cincinnati. He is now retired from modeling at age 83 but the man has way more “wood” hanging on his walls and more first place trophies than I will ever hope to have!
I have done one step further I put down a drop of future (Depending on the size of the decals) where I want it and slide the wet decal right onto the wet future. Let it dry and the future will suck the decal right down as it dries.
I would treat it like any other desert vehicle. A couple washes of different sandy-brown colors and a couple dry-brushes of similar, but different colors. Sorry, its not scientific, but it works.
Thanks for the advice 165spc, and the compliment. One question; The tanker is flatcoted with Testors, can I still apply washes/filters over top of dullcote?
Everything I’m seeing on YT suggests enamel over gloss varnish.
What to do?
(Heavyarty/ Gino please feel free to jump in on this)
Thanks guys, I used MM sand diluted for the first wash. Dried a bit cloudy in the corners but should clean up. The web says to leave for a week between coats.
As to this Marine Mk23 Cargo Truck seen just above - that is a light dusting of sand/dust pastels over Tamiya Olive Drab (rattle can) base coat.
The very faded fiberglass hood effect is achieved using multiple heavy applications of the sand/dust pastel, again over the Tamiya OD base coat.
Using a somewhat stiff, wide (1/4 inch) bristle brush. I scrub the pastel stick in order to release and pick up the dusting powder off the pastel stick. I then scrub the pastel powders into the tooth of the matte clear. This makes for an ALMOST permanent application with no need for an additional clear overcoat.
One thought/Suggestion/Warning Here:
When I look real close at your big flammable decals I see tiny speckles where it has glazed away from the tank surface below.
My advice would be to NOT use any sort of transparent washes over this. A transparent wash is a filter. A filter will darken the good areas of the decal to the same degree it darkens the speckles so no matter how much you apply you will still see the speckle dots.
The pastel dust is microscopically opaque so it will to some degree help HIDE (cover over) the speckles rather than just making everything darker. It is just like a lady (or man - being full on PC here) putting on a makeup base to hide skin blemishes.
Not at all sure I am making my point clear here???
Hobby Lobby has all the oil pastels you could want in artist’s sets. Just make sure you are not getting colored chalk.
You will want the lighter colors; sand, lite yellow, rust and mud brown.
This is the set I bought sometime around 1974. I am not a sketch artist and just use these only for model weathering so with the exception of buying a few replacement colors this set has lasted me all this time. (Currently available on eBay.)
