Shermania 2026
Lots of parts but once you get into a rhythm it goes pretty well and the provided jig helps. With patience and care the tracks turn out nicely. Used them on my RFM Firefly.
Well here we go again!! I’ve ordered the Academy Priest and while I wait for it to appear I’m making a start on the Academy M-12 GMC. I’m leaning towards doing Adolph’s Amnesia simply because the name appeals to my warped sense of humour! LOL Any way here are the obligatory starting pics.
P3080001 by Chris Wilson, on Flickr
P3080002 by Chris Wilson, on Flickr
Chris
I’ve posted a list of finishers in Shermania 2025. Please have a look and let me know if I missed you.
Michael :israel: :face_with_tongue:
I’m there so it looks good! :grin:
After some thought it occurs to me that both self propelled guns I’ve chosen to build are based on the M3 chassis. @michaelsatin I need to think of something else yes?
Chris
I didn’t want to point that out when I saw your post, but yes, they’re both M3-based. Unless you want to convert the M7 to an M7B1, as that used an M4A3 hull?
I got there eventually lol. I’ve considered trying to convert the Priest to the B model though I don’t think it ‘d be either easy or that I have a donor kit to rob. So I’ll likely go with building a M51 or I have a couple of Sherman’s that could be built.
Chris
Sorry, Chris. But I’ll bet you have something in the stash that’ll fit!
I was pretty certain that was the case Michael, and yeah a few options. Thinking of building an M4A2 as a 2NZEF 19th Armoured regiment in Italy. There was a recorded case of one of their Sherman’s driving up on a Churchill or possibly a Valentine Ark to get enough elevation to reach a German Self-propelled gun that was harassing the infantry. That’d make an awesome diorama.
Chris
The easiest way would probably be to saw the whole engine area off an M4A3 kit, replacing the grilles with gratings, and grafting it onto the M7 kit. However, as this is all flat plates, scratchbuilding it shouldn’t be that hard: build the upper rear plate first and then add the engine deck and sponson roofs, and you’re most of the way there. The main difficulty would be the exhaust deflector, though that can be taken from a kit or a set intended to detail an M4A3 kit.
I don’t know what nose the Academy M7 kit has, but you’d probably have to replace it with a sharp one.
However, all of this means you might just be better off buying an Italeri M4A3 and an Italeri M7 Priest, then kitbash the two, instead of converting the Academy kit …
I’ve seen a publication on the M7B1 which might be a good starting point for me to decide if I really want to convert the the kit or do as @Jakko suggests . I think I have the correct transmission housing (Possibly maybe??) from the M10 build, you get a whole lot of spares from the Academy kits. Either way it might be an interesting avenue to explore.
Chris
I didn’t remember that Academy’s M10 comes with two different noses (according to its instructions that I just looked at on Scalemates), so if you have the sharp one left, chances are it fits the M7, which would be a major help to doing a conversion like this. One thing I forgot is that you would also need late bogies, with the support roller bracket behind the bogie bracket, but according to the instructions, there’s a set of those in the M7 kit, so that shouldn’t be a problem at least.
@Jakko I’ve looked at the Italeri Priest kit number 6580 on Scalemates (love that site) and I’m pretty sure it’s the M7B1 variant as the transmission housing, the rear deck and 50cal “pulpit” look like a M7B1’s, care to cast your eye over it and render your opinion good sir?
It is an M7B1 according to the box art:
Inside, according to the instructions, it’s the same M7 kit that Italeri has had for almost 50 years, though:
This is clearly the hull rear of a vehicle with a radial engine and external air filters, meaning it’s an M7 in the box, not an M7B1.
The easiest way to tell the two apart is by the rear sponson I pointed out in the box art: if the hull side ends at the rear corner of the stowage bin, it’s an M7 — the centre part of the engine deck will extend further back, but you can’t see that in photos taken more or less from the front. But if you can see the hull side go back further than the stowage bin, it’s an M7B1.
Given that then it might be easier to convert the Italeri kit as it seems to be a hybrid of both early and late M7’s. I’ll definitely need some sort of publication to see what else may be needed. Well it’s certainly piqued my curiosity!
And after searching the web what do I find but this article right here on this site!
Chris
The Tankograd Technical Manual book on the M7 is a good source, it illustrates the M7 and M7B1 both quite well. However, I don’t see it on their site so I guess it’s out of print?
There are a couple of editions on EvilBay, which are eye wateringly priced with shipping to NZ being just as much as the cost of the publication, I might see if I can find something here in NZ, or online.
Chris
I’m having no luck finding a PDF of a real M7B1 TM — the M7’s is easy enough, but that’s no use for building an M7B1.
For those not following my actual build thread, here’s the latest on my T6:
(An irony of which, BTW, after the discussion with Chris above about his chosen subjects having M3 hulls, is that the T6 was built on an M3 hull as well :slight_smile:)
Hello
Here is my entry for this campaign
I plan to build a Soviet M4A2 76W entering Harbin in August 1945, accompanied by a detachment of marine infantry from the Pacific Fleet.
