Skis, skids, and floats
Hi Everyone,
As I go through the process of taping off yellow-orange ID markings, I felt that it was certainly time for an update. From my last post, I did start on the cockpit and finished it. I have found that the only thing that ages in plastic model kits are the decals. That said, this kit was made in 1999. Given a 25 year old kit, which is a great one, the decals are a bit on the old side. Skeptical as I was, I cut the decals in order to fit the instrument panel.
The 6 instruments on the left side went down fine, the 6 instruments on the right went down ok, but needed some work to get them to settle (pin holes and lots of Mr. Softener). The top two instruments failed, as did the one’s on the left side of the cockpit, due to drift. As much as I tried, they moved once placed, and drifted about 0.5 mm. So, they were removed, and replaced with either a decal from Airscale, or some black paint and white touch ups. I also added some Eduard seat belts, from my research it appears that no shoulder belt was used on the float planes in INJ 1943.
Prior to placing the cockpit into the fuselage, I took the opportunity to paint the “black” areas of the fuselage and the engine cowling using Tamiya NATO black which is really dark charcoal grey.
With that done, I glued the cockpit into the fuselage, and then then glued the lower wing onto the airframe.
With the fuselage and wings taken care of, it was time to focus on the canopy. Fortunately, Eduard makes a perfect mask set. Using my razor saw and fine grit sandpaper, I prepped the clear parts…
Then masked them.
The canopy was attached using white glue, and once dry, given a coat of NATO black for the interior, and then the whole plane was primed using MS1500 Mahogany.
Till next time, wash your hands with soap and water, and have a great time!
@ John (john41492). Nice work so far. Looking forward to seeing your ‘Rufe’ build progressing. :hammer_and_wrench:
フライネイビー! :saluting_face: :jp:
—mike
When leaning over the rail, don’t fall off the boat!
:woozy_face: :nauseated_face: :face_vomiting: :ocean:
Continuing with the deck and stanchions… The base is painted and the first rung of rope has been threaded. :sewing_needle: Note: The dangler is where the drill-bit previously broke. I’ll deal with that later. :adhesive_bandage:
Front sides are painted. If you can see the rivets, yer too dang close! :magnifying_glass_tilted_left:
• Tamiya Ts-6 Matt Black (rattle-can)… pre-shading primer
• Tamiya Ts-99 IJN Grey (Maizuru Arsenal) (rattle-can)
• Syren Ship Model 0.012” (.30mm) Ultra Tan Scale Rope
The two back quarters are painted black.
• Rust-Oleum (7798830) Black Semi-Gloss
Made a couple of extra stanchions, just in case. :hammer_and_wrench:
You’ll notice, there was paint bleeding on deck — took a chance and used the wrong masking tape. :game_die: :game_die::waving_hand::face_with_raised_eyebrow: Learning from that mistake, I went and grabbed a roll of ‘FROGTAPE.’ That stuff is the shiznit! :+1::kitchen_knife:
Thank’s for having a look!
フライネイビー! :saluting_face: :japan:
—mike
Trying to get back into this Bird Dog build, scale modeling can be fun when our skills are challenged or it can be frustrating when a particular kit is either above our skill level or if it’s just a poorly engineered kit . . .
. . . shjeese, it was a fight to get the pancake six cylinder engine set in the engine mounting frame and with any luck I’ll get the cowling cemented around it . . .
When I first gave the model a cursory look over I didn’t notice much flash, but once I started working on it I discovered almost every part has offset flash, the mold halves just weren’t lined up right. Roden uses a soft brittle styrene that can be trying when attempting clean up, two of the motor mounts broke during construction and had to be repaired in order to keep going. This bad dog may be above my skill level but it’s too soon to tell.
Cajun :crocodile:
@ Terry (agincajun). Chia Theory: Flash, pin marks and sink marks grow whenever a kit is exposed to the Earth’s atmosphere. :face_with_diagonal_mouth:
The ‘Bird Dog’ is too cool. Keep at it! :saluting_face: :us:
[EDIT] Image added.
Both railing ropes are threaded now, stanchions are ready for placement… but not until I take care of that annoying paint bleed. :face_with_symbols_over_mouth:
—mike
DSC01232
First coat of German Grey on the upper body using a #5 flat brush. Next coat will use the smaller brush to get into those untouched places.
Back to the airframe… :hammer_and_wrench:
Instrument decals were applied yesterday. Fuselage halves were joined together today.
:clamp::clamp::clamp::clamp:
—mike
With the floor pan, seat frame and joy stick cleaned up and glued in along with the control pedals it was time to hose down the interior with chromate green . . .
After spending hours cleaning up the window recesses and window frames, meticulously checking the fit of each window, I decided it was time to glue the wing halves together, did I dry fit the parts? No. Did they go together right? No. That’ll learn ya dern ya.
Cajun :crocodile:
John, very nice cockpit!
Gary, looking good - the schwimwagen is coming together nicely!
Terry, nice job on the interior and pilot!
Looking forward to see more.
The Schwimmwagen really is coming along. I might finish by the end of the month. Working on trying to paint small things on the instrument panel, which has not been a success with my wonky eyesight. I did finally get the wiper motor on the windshield. Honestly, Tamiya should have molded it right on to the frame instead of making it separate. It’s soooo tiny.
There are some sadists working at these model making companies. I thought Miniart employed all of them, but it seems that the other manufacturers do as well…
Never built a Miniart kit, but I have 3 in my stash: M3 Lee, M3 Grant, and Tiran 4 Shrir, all with interiors. I have a feeling, they will all stay unbuilt or I’ll sell them.
Try one. Sure, MiniArt kits can be challenging, but with a little (or a lot) of patience, they build up nicely. IMHO.
—mikey :spoon::yum::bowl_with_spoon:
Gary whether you decide to build one of your MiniArts with the interior is your call, personally considering the limited veiwing it seems a waste of time and effort, maybe trade them for an M10 or M26 that have an open turret or swap for a straight Lee or Stuart or Grant. Keep us posted buddy :slightly_smiling_face:
Cajun :crocodile:
Jake wants to do a fly-by… :collision::collision::collision::collision::collision: :collision: :collision:
Here’s my version of the cockpit MG Mount… too bad, there won’t be an MG mounted on it.
Just some Styrene scraps cobbled-together plus a MENG nut. :kitchen_knife: :hammer_and_wrench: :nut_and_bolt:
Here’s the mount in situ. Never mind the black CA on the fuselage… still sanding away at it.
—mike
Not a CAT launch yet…
Just a dizzying carousel ride. ‘Jake’ got some primer all-round today. :circus_tent:
• Tamiya Fine Grey Surface Primer (87064)
The fuselage is still only dry-fit to the wing assembly at this stage. Fit is very nice!
As always, thank’s for having a look!
—mike
Hi Everyone,
Cajun, I’m really enjoying your Bird Dog build! Great attention to detail going into a small area. Gary, looking good so far. Mike, having a special spot for Japanese float planes, I’m very much watching what you’re doing. So far looks great. Having the Nichimo Jake in 1/48, I’m faced with having to scratch a cockpit. Your build has given me some nice ideas, thank you.
In my last episode I had completed the airframe and was beginning the process of getting some color on her. Given this was a bird that was stationed on an island the potential for weathering was certainly there, however, for this one I wanted to have it look as it would of shortly after being dropped off on the island. Additionally, I was going to use a combination of painted insignia, a set of Techmod decals, and the kit decals. After all, I have quite an inventory to build, and painting the insignia on each of them will really bite into what time I have left (yeah, got a lot builds yet to do!). So, on with the show!
The airframe was given a coat of Mr. Sufacer (MS) 1500 Mahogany, since the original bird was most likely primed using a red/brown primer. For painting purposes and a black base technique, using artistic license I felt the Mahogany color was a good base.
The first part of the color scheme I did was the orange/yellow ID bands on the wing using Mr Color (MC)58.
These were then masked off at the appropriate locations.
Then it was time to move on to the insignia on the wings. These were hinomaru’s with no white boarder, so pretty easy to do, using a compass razor and frisket paper I cut the disks following the diameter from the kit decal sheet. I first painted the areas of the wings light grey, to give the red a good clean background.
The grey areas were then followed up with a coat of MC385, red IJN (aircraft markings), it should be noted that insignia red would also work just fine for hinomaru’s.
The cut frisket paper circle masks were then placed in their appropriate places and burnished down. It was around this time that I became aware that I’d spent a goodly amount of money on various decal sets, and while it’s cool to paint your insignia, it would be a shame to let the decals age out. So, I decided that for the fuselage insignia and limited stencils I’d be using a Techmod set as they had the hinomaru’s with the white boarder, and instead of making masks for the aircraft identification I’d be using the kit decals (this would include the cool lightning bolts). That said, I proceeded to paint the undersides JN Grey (Tamiya XF-12) because I prefer the slight tinge of green added. It makes a slight difference over other IJN greys out there.
With the bottom painted, I masked portions of the underside to prevent overspray, and proceeded to paint the uppers, using MC15, IJN Green (Nakajima) and white 1:1. This would be the appropriate color since all A6M2-N Rufe’s were produced by the Nakajima company.
I also took the time to paint up the main float at this time as well.
With the majority of the painting completed, I removed the masks, and my burnishing job was sufficient to keep the main coats from leaking under the masks, whew!
With the painting mostly finished, the bird got a coat of clear, and I moved onto getting the engine completed. Hasegawa does a very nice job on the engine, which after painting, took a black wash and looked quite convincing. The engine was then attached to the airframe as was the main float.
The cowling was painted NATO black and attached. A little more clear was applied and it was time to start decaling. The decals were so-so. The Techmod decals responded fairly well, though the “no walk” area on the starboard wing got a kink in it and refused to straighten out, and there was a little tearing on one of the hinomaru’s, though not that noticeable. The kit decals were overall fairly good despite their age, with my only complaint being that the lightning bolts were a little on the translucent side. Since this became an experimental bed, I feel pretty good as to how they turned out. All the decals settled down just fine using Mr. Softener.
Once decaling was complete, the entire bird got a sealing coat of clear. Once dry, I gave the entire plane a wash of burnt umber and white, highly thinned with turpentine. The goal of the wash was to be dark enough to highlight the dark green areas, and light enough to highlight the cowling, and give a sense of being in a saltwater environment. I think I came fairly close.
With the wash cleaned up, it was time to dull things down. I used Skull Color matt varnish 120.056 acrylic color (Zeon Plamo Co. based out of Banga Bangkok, Thailand. These paints seem to have a big following from Gundam builders, not sure of availability, but I really like the stuff, you get 60 ml ready to use for around 4 USD). Following the dull coat, it was time to fit the radio antenna wire. On a plane such as this, it’s a two-step process for me. First, I very gently make a starter hole using a pin in the pin vice and use the hole for further drilling using a 79 drill bit. The trick here is to go slow and purposeful, as there could be a danger in splitting the rudder halves (ask me how I know!). Then using fine EZ-Line (charcoal color), one end is superglued into the hole.
Next, I take the loose end and pull it (not a lot of stretching is needed, basically pull the line taught) placing a bit of superglue on the antenna and laying the line over it. I will also put something on the loose end to help hold things in place, in this case a baby clothesline clips (think stationary shops). Once dry (min of 10 minutes) the line is trimmed, in this case I used fly tying serrated scissors, a first for me, and I really like how it went!
With that completed, I plunked the propeller in (gently), and called this project done!
I have an affinity to floatplanes and flying boats. This affinity has led to a general interest in the IJN Kamikawa Maru, a seaplane tender of note. I find its history, and the mystery of the murder of her surviving crew a few weeks before the end of the war as fascinating. Sadly, the mystery will never be solved. That said, the Kamikawa Maru lead an interesting war career, from launching harassment flights over Guadalcanal, delivering planes to Alaska, and throughout the Soloman islands till her demise in 1944, when a sub sank her.
“The 934th Kokutai (Flying Group) was equipped in March 1943 with between 8 to 10 A6M2-Ns at Ambon Island in the Dutch Indies, having moved there from Taberfane in the Aru Islands (delivered by the Kamikawa Maru). They regularly met Bristol Beaufighters, Lockheed Hudsons, B-25’s, and B-24’s” (aeropedia.com.au).
The primary purpose of the 934th Kokutai was to provide aircover for the Boela Oil Field, located just North of Ambon Island. Also, to provide aircover to E-13 “Jake” and F1M2 “Pete” reconnaissance and search and rescue of downed pilots. Despite overwhelming odds, they did give a good showing of themselves. While the Boela Oil Field would remain in Japanese hands until the end of the war, the Allied forces simply bypassed it, as there was no real way to get the oil to Japan by the first quarter of 1944. The 934th Kokutai was disbanded in March of 1944, the surviving pilots having claimed 29 aircraft destroyed and seven probables for the loss of five pilots. All things considered, not bad.
I present a A6M2-N “Rufe” of the 934th Kokutai, as it would have most likely appeared in the April/May 1943 time period. Enjoy!
This build also completes a nicer picture of some Kawakami Maru’s work. seen here with Tamiya’s A6M2-N from the PTO campaign group build, 6 years ago.
Overall, this is a pleasant and fun build. Hasegawa’s rendering of the Rufe has much nicer detail as opposed to the Tamiya offering, which should be expected given that Tamiya molded their rendition in 1974, and Hasegawa was done in 1996. While getting a bit on in years, it makes into a very nice kit. My biggest complaint (not that big) was attaching the main float, which was a little fiddly, though I blame the builder more than the kit. I highly and fully recommend this kit to any modeler with a plane or two under their belt that is wishing to add a floatplane to their collection. With ease of construction, and good layout for painting with endless possibilities for weathering!
Till next time, be safe, wash your hands with soap and water and have fun!
Very nice!
@ John (john41492).
Your ‘Rufe’ is absolutely beautiful! :star_struck: I really appreciate the concise painting log, as I am a complete noob at this stage. Also, I very much enjoyed reading the backstory of this iconic floatplane. … Very nice work all-round! :hammer_and_wrench: :art::paintbrush:
—mike
Beautiful Rufe!
