Hi everyone,
there is still the supplement to the nozzle pipe on LH2 TSM, which now also waiting for the final assembly and mounting to the 24’’ ring line, which will follow soon.
And so I would then also have crossed through the maze of SSWS pipes.
After lately the pipe diameters became smaller from 24’‘-18’‘-16’‘-12’‘- 9’’ down to 6’', it now once again goes back to the thickest 36’’ pipes (Ø 6,3 mm), through which both ring lines being supplied with water.
The connecting pieces of the feed pipes in the corners of the SRB Chambers I had mounted already during bending of the ring lines.
3D-rotatable view of this area at nasatech
Source: nasatech.net
Here is another great panorama view from under the MLP.
And now it comes to the lower end of the tube with the connecting piece, for whose items I have again estimated their dimensions.
For the construction of this connecting piece I have imagined that I could cut the 6,3 mm tube into short rings, which are subdivide by punched plastic discs (0,15 mm) and finally are glued together. ![]()
The more difficult part of the exercise subsequently follows, when these tiny stiffening ribs and corners must be glued all-around, for which I already have an idea,
but what could become quite a tricky fumbling.
As far as for today.
especially because the connecting piece still can be disassembled.
