Arma Hobby 1/72 P-51D Mustang double build
This is one we have waited a long time for!
It’s been almost four years since the Arma B-Mustang was released and even before that Arma officially was talking about a coming D-version. For some, to me unknown, reasons this process took a long time and Eduard beat them to the market with more than a year (the Eduard kit came last summer and is excellent, I have two different double-boxings of it where I have started one but haven’t posted anything yet, I will come around to it in due time though…). Let’s see what Arma has to offer!
As always, a very stylish box-art of a legendary pair of machines!
Two, well packed, sprues…
…nicely cast in light grey plastic.
A set of thin and very nicely done clear parts. Since I’ve already started talking about the Eduard kit and in case you wonder: these canopies are ever so slightly both clearer and thinner than the Eduard parts. Not by much but there is a difference to Arma’s advantage.
And since, according to the rules around here, you are always allowed a head start with building: here are all the major parts needed to build two Mustangs!
Today almost all premium kits contain a bit of 3D-print, at least the ones from Arma, IBG and Eduard. I just love these seats! There are also 3D-printed cannon and exhausts, the exhausts will come in handy but for the cannon I prefer a set of turned brass pipes.
A clever solution to a tricky painting problem: paint the whole surface primer yellow and then add decals! With the aid of setting solution the decals settled nicely arouond the raised detail.
This is the B-wing from my earlier build showing how the ribs cast to the top surface effectively made masking impossible, I ended up hand painting the details and then adding a wash to sharpen it a bit. It turned out well but it was a lot of work. The decals are much simpler and, thinking about it, just the fact that the ribs are a loose part now opens up for easier masking as well if you don’t want to use the decals!
And then the question of markings: as all modellers know, Bud Anderson’s “Old Crow” is mandatory. However, none of the other two markings from the box really appealed to me but with two Eduard double boxes on the shelf there is an abundande of markings to choose from without resorting to after market decals. In the Eduard “Aces of the Eight”-box there is a set of markings for Urban L. Drew’s “Detroit Miss”, as close to a world class super-celebrity ever a plastic model can be :slight_smile: ! I base this on the fact that it was the main marking choice for the Monogram 1/48 kit for many years. Apart from that I’m quite fond of yellow markings so that will be perfect.
And finally, the unavoidable comparison to the Eduard kit: I haven’t checked them side by side but the Arma kit is without doubt a very nice kit. It has everything needed for building a -D or a -K with or without dorsal fins, including parts for the PR-variants. There are two different kinds of drop tanks and also a set of bombs. Eduard has managed to cram in even further drop tanks and rockets as well but I think both kits will result in very fine Mustang models when they are finished. Arma’s plastic doesn’t look as refined as Eduard’s at first glance and the ingates are bigger (Eduard has really done a lot when it comes to their ingates) but as soon as I started building I found that Arma are back at the top of their game again.
So, all immediate problems solved, let’s go building :slight_smile:
:man_raising_hand:
Magnus
I’m following along Magnus, quite weird but I just pulled the trigger on a Eduard 1/48 P-51 and an overtrees box so I can build a post war Italian airforce F-51D-20NA using an Xtradecal set which I ordered just now as well. The other P-51 will get either markings from the box or one of the other 14 schemes on the decal sheet, possibly Siam or Haiti.
Edit; Somalia not Siam :face_with_open_eyes_and_hand_over_mouth:
@Littorio I think an Italian Mustang is an excellent choice! Italy had a really interesting air force after WWII, other things I have wanted to do are a Thunderjet and a Thunderflash. And why not a T-6 to go with the Mustang? For your second Mustang i can wholeheartedly recommend doing a Swedish one, it is well known that that is a MUCH better choice than Siam or Haiti. Much better. Everyone knows that…
Interior painting. Once again a very complete interior with quite a lot of decals for the placards. Instrument panels are decals over standard plastic parts as well.
Wheel well interior parts in place. Here you see how this way of splitting the parts facilitates painting enormously.
Two almost finished Mustangs! I’ll have to do a bit of priming, especially around the tails, since they didn’t fit that perfect. The separate fins with/without dorsal extensions seem to be tricky to get perfectly right in the kits, it was the same with the B-Mustangs. The stands are included in the kits, they are prepared for aligning the landing gear as well.
This is a tricky area to fill and clean up, it is a lot easier just drilling holes and adding Master barrels.
:man_raising_hand:
Magnus
Hell yea, love your work, especially in the “Gentleman’s Scale”. Looking forward to the finished Mustangs :call_me_hand:
:slightly_smiling_face: Magnus I’ll take your word for it and the Swedish one does indeed look nice but the Haiti bird in light grey with red wing, tail and spinner tips, fixed tail wheel, F-86 drop tanks and modern (1963) antennas just has it for me. If I get around to a third and forth then a Somalian and Swedish pair will join the party.
Anyway are you sure that that is a 1/72 kit as the detail looks superb as well as your painting.
Watching with interest Magnus… looking good so far.
@FlyEaglesFly Thanks for following and always nice to find other 72ers!
@Littorio I see your point :grin:! If you ever get around to that Swedish J 26, this is where you should get your decals. Regarding the details, whenever a new model is released I open the box with great anticipation to see what they have achieved this time and I’m seldom disappointed! New 1/72 kits really pushes the limits when it comes to detail level. The research put in by the best ones on the market (Arma, IBG and Eduard are my favourites) is also impressive and directly translates in to more and better detail.
@Russelle Always good to have you onboard :slight_smile:
There is no way of avoiding that scary metal painting anymore, I just need the windscreens in place and then it’s “go”. You can see the remnants of a first layer of primer around the areas that were “potentially problematic”, with a little more care while building I think most of this could have been avoided.
Both machines got K-14 sights. Most of these early-block P-51Ds were delivered with a simpler reflector gun sight but considering that both the pilots were aces I suppose they both had gotten gyro sights. Note that I have glued them before attaching the windscreens, I’m really working on self improvement :slight_smile:. Normally I would have waited until everything was finished, then trying to add the gun sight last, dropping it into the cockpit where it quickly would have glued itself to the base of the control column. This then would have led to lots of calls to customer service from pilots complaining about lack of victories and aching backs while trying to aim while bent over double in the cockpit…
As a warm-up before the scary process of painting the whole airframe, there are lots of smaller parts to practice on!
:man_raising_hand:
Magnus
I had forgot about Moose Republic, I have kept an eye on them for their Draken and Viggen decals.
I agree regarding the quality and detail coming from Arma, IBG and Eduard in 1/72, I have all of IBG’s Fw-190D kits and most of Eduard’s Fw-190’s as well in 1/72 and a couple of Arma’s Wildcats.
Nice progress on the P-51’s and it’s always good to see bits on sticks.
I’ve been mustering what courage I have to get the metal painting started…
First step is MrP “Super Gloss” black…
…followed by MrP “Super Silver” as a base, I will complement this with panels masked off and painted with other metal colours later on. After this, I masked and painted all surfaces that were “silver painted” in real life, mainly the wings and the flying surfaces. I mixed MrP “White Aluminium” with a few drops of white to get more of a silver lacquer than a metal finish. Don’t overdo the white, the paint turns grey very quickly.
I also masked the spinner seen in the first photo, here is a useful formula for cutting a tape circle with the right diameter to wrap around any reaonably conical object.
:man_raising_hand:
Magnus
Work is ongoing. 2026 as a modelling year seems promising :slight_smile: !
A friend of mine pointed out that the ammo covers were painted with the rest of the wing (if for no other reason it worked as masking for the wing interior) so some quick additional wing painting was called for. An unintended advantage is that I got some tiny contrast to the surrounding areas, avoiding that all-grey look!
I’ve also started masking off and painting panels on the fuselages. MrP is really nice, just let it set for a few minutes and with careful handling you can go on working on the next panel.
:man_raising_hand:
Magnus
Those are looking great. Been thinking about picking up a couple of Arms Mustangs, probably a B or C kit. Done a few D’s from various other makes over the years, but hardly ever touched the early versions.
@phantom_phanatic You can’t go wrong with the Arma P-51B/C! I did a pair of them when they were released - already four years ago by now… They are fantastic kits, a joy to build!
:man_raising_hand:
Magnus
I remember following those builds. They turned out beautifully.
I’m looking at the Burma boxing of those kits. Haven’t done much from that campaign.
@phantom_phanatic The rule is that for a Mustang, you should stick to 8th AF, possibly throwing in an RAF machine flown by a Polish pilot :grin: !
Detroit Miss…
…is starting to look better and better. Yellow is always such a happy colour! Note ghost in cockpit!
Poor Bud has to wait for his turn. For safety reasons he’s got a set of D-day stripes to reduce the risk of getting shot down at this early stage…
I can’t duck it anymore, I HAVE to take the time to do a set of masks now. I’ll probably make a try even with the “OLD CROW”-text to avoid a decal on the anti-glare panel.
Have a nice weekend all!
:man_raising_hand:
Magnus
Used to drink Old Crow back in the day…
That is true. You have to do at least one 8th AF for the collection. For some reason I’ve yet add an RAF Mustang to the collection. Somewhere I have a set of decals for one Leonard Cheshire flew as a Pathfinder on night raids. Possibly one of the missions he was awarded for VC for.
The P-51 is looking great. Very neat paint work on the stripes and yellow.
Great work as usual, Magnus! You may remember my Mustangs Mk. IV (not P-51) double build from 2022. One is canadian and the other australian. No polish pilot in there … :grin:
@Dan I’m not a whisky drinker but IF I was I would drink Old Crow :slight_smile: .
@phantom_phanatic Thanks!
@BlackWidow I remember your Mustangs! For you who happen to have forgotten them, go back here and have a look! Worth it even without a Polish pilot :slight_smile: !
I’ve been painting markings, bit by bit, during the last week.
The old crow finally got it’s name…
…I did it “the inverted way” since it was easier to get the individual letters to stick and stay down than to form the rather large negative mask over the compound surfaces of the nose.
Both of them together. I’ll do the station signals for “Detroit Miss” this afternoon as well.
Have a nice weekend!
:man_raising_hand:
Magnus
Actually old crow is a bourbon, but I think getting the two mixed up is only a big deal in Kentucky. Bud Anderson’s book is pretty good too.
@Dan I read Anderson’s book when I did these a while ago. Remark on bourbon/whisky noted with thanks!
With masking removed and props loosely attached I think we can almost see the end of this project!
Will try to get some more small stuff finished today.
:man_raising_hand:
Magnus
