Older versions had the weld lines visible. Later ones had the weld lines grinded smooth so that it could not be seen. Both types were in service at the same time though, so either way is correct.
My Entry for this campaign: IAI RC2 Kfir Tsilum
I haven’t started working on them yet. I’ve only opened the blisters and prepared some resin pieces.
Thanks HeavyArty. I recall having both. In this case, I’ll give it a whirl putting welds on it.
Mike
Happy to say that all the removal of all molded on parts that will be replaced with either Legend or Eduard parts is complete. The 4-duece generator is built and painted the 70’s (around there anyway) OD.
Sometime back I picked up a few of the Perfect Scale Modelbau “spade boxes.” One of these will be placed on the roof as all my M577’s seemed to have one of those.
Mike
Don’t forget Mike, once it’s finished, a few completed images would sit well in …
And a bit of a back story about the wagon and you … ![]()
Looks very nice!
Little update on the M3:drivers part is nearly finished…
Figures to go into it took a bit of work to get them to fit…
And the rear, busy with adding the radio’s…
They will need some wires and stuff…
And adding seats in the rear…
Not sure yet about howmany seats, two or three… leaning towards three…
And bit of dry fitting to see what it will look like…
Decided to try a test fit of the RTR flag for Nomad which was flown from the rear antenna base.
I used normal kitchen foil ( I think Don suggested this way as well) as the backing and then micro set and sol.
I made sure the foil was completely smooth before attempting it all.
Turned out really good. The white edges crimped up a bit but that won’t be an issue as the real attempt will have those cut away and another flag put on the reverse side.
The above trial run was let to fully dry then I really went hands on, crumpled it completely, folded it, then unfolded and that’s the end result… No real damage at all and no visible foil… ![]()
Edit. What looks like white areas on the red/brown is just camera light reflection ![]()
Looks really good! Was that a decall or a normal piece of paper the flag was printed on?
Self made decal on decal paper. I did one sheet with about 12 flags on it
And thanks Bert … I was really amazed how little damage (practically none) was actually done to the decal with the tin foil backing in place…
And just to prove it again… I just scrunched it all up again …
And re-flattened it… Again, almost zero damage (this was the third time I’ve done it now)
1/24 Masterbox figures primed. The carbines are from Large Scale Armory.
I made the mistake of gluing the female corporal’s arm upright first before tucking in the M4/M203 into her armpit. Hence I made her hold a pistol and gave her an empty holster for two pistols on one figure.
That’s not very realistic. Why would she not have a long gun and have two pistols? Two pistols are not usually carried, not even by SF. It would be more realistic if you put the empty holster on her leg and slung the M4 across her body w/a strap.
@HeavyArty True, but I’m not going to sweat it.
I learned that CA Debonder doesn’t work on Gorilla Glue unless I saw her raised arm and thigh pistol in holster off which I am not going to do.
The only other options would be to have the M4’s buttstock rest on her elbow (not under her arm), or arm her with the original MP5K, which both other options are unrealistic. At least the pistol she’s holding has an underbarrel flashlight. ![]()
These aren’t my best or most expensive modern figures so I’m just going to let it fly “as is!” ![]()
@Maximus8425 … Can you remember off the top of your head the fitted length of bowman antennas ? I keep thinking 2.3 to 2.5…old age is catching up lol… And no matter what I type, Google isn’t playing nicely …
Right in between, 2.4 metres. Lower section is 110cm while the upper is 130cm give or take.
A gentleman and scholar !! ![]()
Update on my build:
Needed 2 radio operators for in the back of the M3, so decided to reuse these:
Bit of cutting and repositioning of limbs…
But than I noticed their heads were sticking up too much above the sides for the roofsection to fit…
So, had to rais the roof a bit…
After all, that roof was part of why I switched over from the Tamiya to this Dragon kit…
Nice surgery on the figures Bert.
Thanks John, thought it made a nice couple of arguing radio operators ![]()
