Hello everybody,
and it goes on with the new lining of the SSME Blast chamber, which was to be seen. In this case, it strikes the experts immediately that the template from D. Maier’s Paper kit has no step-shaped shoulder, but it is present in the original.
First, I detached the struts and already started sanding the glue on the backs.
For that I had initially used Evergreen profiles 1,0 x 1,0 mm. However, this thickness appears to me to be somewhat oversized from today’s perspective and in comparison with more recent original images, given the proportions in the chamber.
Came across it during the sighting of my photo collection in preparation for the construction of the SSWS. Meanwhile, there are in particular from last Shuttle missions awesome NASA panoramas with high resolution, on which one can do great detail studies.
And here is one image of them, where one can also see the SSME chamber very well from below.
Unfortunately, NASA has changed the Panorama URLs so the link no longer works and I can only show a close-up.
In this image I have determined the thickness of the struts using the grid distance compared to the template, which should be not 1,0 mm but only approx. 0,6 mm. Now this is not a great difference, but it does come much closer to the original and thus fits better by its proportions into the image.
And if you look closer, you will also recognize that these are not prismatic profiles but rather thin tubes.
Here is another working Panorama view from the SSME Blast chamber, where one can see the thin tubes on the walls.
3D-rotatable view of this area at nasatech
Source: NASA
Accordingly, I have placed some profiles for comparison on the template.
In my opinion, Ø 0,64 mm rods would probably fit best, but maybe it will be a bit more difficult to glue them clean than the square profiles, what do you think?
And the struts have to be painted anyway new.
